Boost Gauge - Digital or Analog
CONSIGLIERI
181
Oct 6, 2010
Columbia, South Carolina
Hello friends !
I do have an analog boost gauge installed in my car and I'm planning to change it's brand because it's larger than the A-pillar I purchased.
I'm willing to get a Cobalt Autometer and I need some advice.
Should I get a digital one or can I keep the analog ? I plan getting ECMLink later. Will it affect this ?
Thanks !
Mechanical or digital is up to you. I prefer mechanical but that just me.
If you plan to run speed density, you'll be able to log boost with the MAP sensor anyway. I don't know if digital boost gauges can log through link or not.
Depends if the gauge is electrical and if it's MAP sensor is supported.
I know AEM is however, the AEM MAP gets finky when it's signal is shared with two sources.
I've had both and prefer my AEM Tru Boost. I had a Pro Sport Premium before, it was slow to respond and felt cheap.
so if running SD we dont technically need a Boost Gauge because we can log our map sensor?? In my case i have a omni 4 bar so i wouldnt need to have a gauge? Is that what your trying to say. Just trying to get my head on straight here.
Its still a good idea to have a boost gauge because you probably won't have your computer beside you all the time.
It all depends on what you are planning on doing.
Get a digital gauge if you plan on getting the Link V3, you can have the ECU target a boost point using the signal from your digital boost gauge.
Else, i would go with an analog for just a reference.
