ECMlink boost breakup!!!! I got log and money
bryanzomg
182
20
May 18, 2015
melrose park, Illinois
Well I'll be damned boys, she's getting breakup under boost. AEM IS CALIBRATED WITH LINK, she's running really rich due to the shit SD table (had fueling issue)
If someone can lean her out a bit on SD table I'm sure she wont break up as much. I've got several logs, the cleanest pull for me breakup wise was the 4th gear log.
I can and will pay for a revision!
I see you are WAY over 100 on the VE table so you need to richen up the global. You will need to retune some but VE's in the 120's is a big red flag to me. It shouldn't be over 100, but I have seen some go into 105-108. Just my opinion. Hopefully some others will take a look at your logs and give their input. :)
Yeah we were having fuel issue (clogged fuel filter) so our VE table was screwed up to compensate lack of fueling
I understand. Had the same issue on the sock and fuel tank all last year. Can you start "fresh"? Load a good known last tune or a brand new one?
I didn't even look at the logs yet, but if your VE is at 120, you need to start fresh. If you're still having fueling issues then you just need to wait until you get em fixed
Again
I HAD fueling issues hence the VE table trying to compensate running lean
All fixed now, so now it’s got more than enough fuel
Last good known tune was on a differently setup but I can do that
It may not work real well if it was a different setup but you can try.
