Bolting on a 14B or EvoIII
daltah
516
Sep 27, 2002
phoenix, Arizona
If I were to bolt on a 14B turbo would I need to get new injectors, fuel pump ect to run 15psi? I want to get around 300 crank hp without doing a lot of different mods and tuning. I already have basic bolt ons.
Can you? We have no idea. Get a logger, do a pull and see for yourself. Every car is different, i.e. I can't run 15 psi on a EVO 8 FP and 14b without knocking, others can get away with 18 psi. It's all different. Get a logger, 'nuff said.
You'd be safe with a 190 pump and a set of 550's of 650's. The cheapest/easiest tuning package is an SAFC to tune and a pocketlogger to monitor your engine.
Jesse's correct. You really need data-capturing software or a good set of gauges to really tell what your car is doing. The quick answer is that you PROBABLY won't need new injectors. You will WANT a larger fuel pump. To get a 14b near 300hp you will need to do a lot of tuning, regardless.
  • Wanted 6 bolt NT water pipe
    • chrisman287
