bolt on 50 trim
bcjjones
509
6
Nov 3, 2011
Austin, Texas
Going to purchase a bolt on precision 50 trim here locally. One question I have is, by bolt on does that mean the oil feed and all other lines to and from the turbo are the same as 14b/16g?
Also what is a decent price for a used one with no shaft play? Can't seem to find a new one to compare pricing
It will bolt on assuming its flanged for a mitsu manifold and o2 housing but should use garret (or some other type not mitsu) style oil feed and drain lines.
Oh I also believe they don't use coolant lines so you need to block / loop the coolant lines.
