bogging under boost
TsiJohn333
317
9
Jan 25, 2010
Goffstown, New Hampshire
I have a problem with my girlfriends 1998 gst sypder (automatic).
Mods: upper hard piping w/ 1g bov recirculating
2 1/2 inch apexi N1 turbo back exhaust system with a cat eliminator
greddy turbo timer
auto meter boost gauge
the problem i am having is that i'm bogging under half boost probably about 80 percent of the time. ill be at 3k rpms on the highway just cruising and when i go to spool up it will start bogging and i cant accelerate from 3-9psi. Any higher than that it works fine. it will hold boost fine while its bogging but it wont accelerate unless i gas it harder. It doesn't hesitate at all at WOT either. i just replaced the tps, the upstream o2 sensor as well. I've been having a little trouble though with the position of the tps sensor. could this cause me to bog under half boost. I'm not throwing any codes either. It bogs really bad when i first start it up and drive. ill be at 5 psi and be going no where. it feels like a rev limiter kicking in and feels like something is holding the car back when it does that.
things i have checked:
i checked all my intercooler piping clamps and such and no leaks
checked all vaccumm lines and no leaks
changed the coil packs
changed all the sparks plugs (ngks)/spark plug wires
changed out the MAF
changed the upstream o2 sensor
changed tps (having trouble with the position)
Thank you guys for your help :D i also can make a video if i wasn't to clear on what it does.
i did a boost leak test but didnt find any leaks. i dunno where to begin now.
How are your plugs gapped? Are your wires on their way out? I would start with those things.
i changed the wires and put fresh new ngks gapped to .28.
cool, ill try replacing the fpr tomorrow i have an extra one laying around :thumb:
TPS can be a sono###un...I am 99% sure mine is why my car won't run correctly right now.
im gonna try to fix the tps sensor soon..... what type of upstream o2 sensors are the best for our cars.? i think when i replaced mine, i might of used the wrong brand. The reason i'm saying this is because when i was throwing the the code for o2 sensor the car was doing the same exact thing and changed it it went away for a little bit and now its doing the same thing. i think its a combination of the tps sensor and o2 sensor but which o2 sensors are the best for our cars? i believe i used bosch.
I would (and do) use a Bosch o2 sensor. Also, adjusting my TPS (with the help of DSMLink) got my car running rather well. Good luck and let us know how it turns out!
well i adjusted the tps sensor and its runs a little bit better than before but i know i have more adjusting to do because it is still doing the same thing. so all i do to adjust the tps sensor is measure the volts between the pins 3 and 4,..... and 2 and 4?
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
