bogging down
HIGH_PSI_GST
Aug 29, 2005
Kathleen, Georgia
for a while my 97 gst has had a problem with bogging down. what happends is i will start moving and when my turbo starts to spool sometimes it feels like i got about 20 people in my car. it just gets really slugish but then if i let off the gas then get back on it it goes away...... i dont think its my turbo because its makin plenty of boost. but its weird because sometimes it will do it and sometimes it wont....... anyone had this problem before?? :confused: i was thinkng clogged injectors but idk. please help. also i have a weird kind of grinding noise coming from the passenger side of the motor when ## sitting in the car. it doesnt make the noise when i rev. only when i i start to go a little bit in 1st and 2nd gear. i just had the transmission replaced last week so that might be the noise but im not sure... please help thanks!!
For the first problem. Check all your ICP for leaks, I had a cut in one of my couplers and it did the same thing. I would boost up to a certain point and it felt like i hit a cow. Also what are you tuning with?
Opps, i just checked your profile and you seem to be stock. So yeah make sure you check for boost leaks. How much boost are you running?
i got greddy IC piping, boost controller, fuel pressure regulator, cam gears, intake, exaust, BOV, oil catch can, and plug wires. im spikinig 15 psi. and i used to vacuum at 19psi and now im vacuuming at 13 or so. but i read that when u get after market cam gears it makes u vacuum a little less than with stock cam gears
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
