BoostedTT91
- 285
- 7
- Aug 2, 2004
Elysburg,
Pennsylvania
Recently my car has been bogging down alittle at low end. It doesnt matter if its either WOT or slowing getting into throttle, it boggs down and jerks alittle bit till like 5-10psi and then it pulls fine. I am running a VPC/GCC setup with keydiver chip setup for this setup. Also once i get up past 10psi and its pulling fine without any bogging or cutting out, there is just no power anymore. I have a t3 57 trim with all the supporting mods,COP, SMIM and so on and it feels like a 10psi pull on a 14b. When i first installed the turbo it pulled really hard and now there just isnt anything there. I first thought i was having issues with the MAP sensor but i cancelled that problem out. at 20psi WOT, im not getting any knock and its not retarding timing badly or anything else obvious that would cause loss of power. I just checked the compression today and its 125psi across the board. I do not have any vaccumm leaks or anything. Im not really sure where to go from here. What else could be going on here.
here is what the logger is showing
rpm 4437rpms
injp 12.03ms
knock 0
o2 .72v
tps 99.6%
injd 44.5%
TIMA 13 degrees
MAFS 540.9Hz
COOL 182.7
AIRT 66.3 degree F (temp doesnt ever change)
BARO 13.46psi
VSS 129
MAP 25.8psi
ANA 1 235
ANA 2 165
FTRL 110.9%
FTRM 85.9%
FTRH 125%
GREV 2.02
FTO2 100%
i am still running rich even with the VPC turned back pretty far to lean it out
rpm 4437rpms
injp 12.03ms
knock 0
o2 .72v
tps 99.6%
injd 44.5%
TIMA 13 degrees
MAFS 540.9Hz
COOL 182.7
BARO 13.46psi
VSS 129
MAP 25.8psi
ANA 1 235
ANA 2 165
FTRL 110.9%
FTRM 85.9%
FTRH 125%
GREV 2.02
FTO2 100%
