Blue Devil then rebuild?
Ghostcrafter
232
Sep 15, 2010
Baton Rouge, Louisiana
Well, simple question I guess ... I've got a bit of a head gasket leak right now and I can't afford to replace it and rebuild the engine until spring. I'm looking to run some Blue Devil through it, but my question is this.
Can I still rebuild the engine in the spring after using this? The reason I'm asking, is the "permanent" feature they insist on.
head gasket in a can seldom works.......
pull the head, check it for flat, nill as needed and install a new hg....
I have seen it time and time again, it goops up the water jacket and can cause the water pump to fail
a composite HG and having the head milled will not be much more than the blue devil.....
The Blue Devil will cost me $10.00 ... I work for NAPA/GPC. I've seen it work on a few hundred cars. Just never been able to get a positive response on being able to rebuild after using it.
Yeah, it's Blue...
