Blown 14b?????
KYAWD
33
Jun 30, 2011
louisville, Kentucky
OK well my car hasn't wanted to boost for the past couple days. Its starting to smell like burnt oil inside the car and you can see it leaking where the head meets the manifold.
Anyone have any ideas?
Also I smokes every now and then at a stop light.
What's it doing when you try to boost?
I'd start with a BLT and a compression test. Go from there.
Compression test 130 all cylinders except number 4 it was like 100. Blt has been done haven't check intake track yet.
There's obviously a problem then with that one cylinder. Could be headgasket, could be leaking valves. From the sounds it's a headgasket though.
I'm thinking headgasket to or rings. I guess its time to pull the head off where can I get stock rings at?
Try puting a vaccum gauge onto any intake vacuum source. Here is a chart to help you diagnose.
Well just a update I took my maf off and found a nut loose in there come to find out its off my 14b wheel it ate the Turbo up like no other.
