mach4g63t
- 402
- 1
- May 28, 2007
St. Louis,
Missouri
Okay, so, my 14b just gave up today. It had shaft play. Well, I just fixed my throttle body boost leak and now, today, when I was playing with it I noticed that when I'm boosting (which is still late and a little low) instead of rich, black smoke coming out I'm getting a very consistent WHITE smoke. At first, I almost shat myself thinking I had blown my head or something, but the smoke doesn't come out at idle or even when I'm on the throttle just cruising. It's only when I'm boosting, and then it pours.
So, my real question is, if I don't want another 14b turbo but instead wanted to get a 16g... Could it bolt up to my stock manifold and O2? It's got a full Megan Racing exhaust (downpipe back). I just want to get this out of the way now, since I need the new turbo as it is. If I keep boost at stock levels, should I need to upgrade any fuel mods just yet? I still have a few other kinks to work out before I start pumping up the boost, so stock levels is all I want off the 16g for now.
And, 3rdly...
I noticed that I'm hearing a slight 'whine' from my car in the rear when I was boosting (before and after the turbo started spitting oil). I'm thinking it's the fuel pump? Is it supposed to whine under boosting? It sounds like a small buzzer that's turned down low. I'm thinking the only reason I'm hearing it is because the car is stripped to the bare metal frame from the driver seat back. Any know if it's supposed to make that noise when boosting or if something else is wrong?
This is a handful of problems, but I appreciate ANY info and ALL help. Thanks.
And, 3rdly...
I noticed that I'm hearing a slight 'whine' from my car in the rear when I was boosting (before and after the turbo started spitting oil). I'm thinking it's the fuel pump? Is it supposed to whine under boosting? It sounds like a small buzzer that's turned down low. I'm thinking the only reason I'm hearing it is because the car is stripped to the bare metal frame from the driver seat back. Any know if it's supposed to make that noise when boosting or if something else is wrong?This is a handful of problems, but I appreciate ANY info and ALL help. Thanks.
. I appreciate the info. I think I'm gonna go ahead and try my luck with the e-Bay turbo kit for th 1g. I don't really plan on beating the hell out of it right now and I don't want to go back to the 14b.
So, I have a little bit of oil and coolant in my cylinders. I would say maybe 2 oz or so between all 4 pistons. The piston surfaces look good, as do the valves. How do I tell if the piston rings are good without actually taking out the piston?
