blowing ignition fuses... help
brandon1239
119
Jan 14, 2010
Thornton, Colorado
installed a walbro 255 last night, dropped it in, pumped e85 and drove around for a while fine tuning my car, shut it off real quick to go inside, came out and my car would do nothing (popped an ignition fuse) switched that out and popped another one right after that. i've tried this with 4 different fuses and they all blow. any ideas? my injector clips are a little messed up right now so im going to switch those out but other than that i have no idea.
Is your fuel pump rewired? I would start checking things you changed before you started to have the fuse blow, It could be something you might have done or have nothing to do with it at all. But i would look at any variables you changed and go from there.
