1G Block and transmission removal
91talontsi0324
101
Dec 18, 2008
pittsburgh, Pennsylvania
hey guys im in the process of replacing the motor in my 91 talon tsi awd. I took the head off yesterday and now im stuck. The block and tranny are still attached. I was wondering if i could get the block and tranny out together. If so can someone give me some advice on how to do it. Any help is greatly appreciated. thanks in advance
If you already have the head off it is pretty easy from that point. Drain the tranny, drop t-case, pull the axles, remove the clutch slave cylinder, unplug speed sensor, remove starter, unplug knock sensor, attach your hoist and pull all four motor mount bolts and lift.
Mike
