Blitz TT install, wont stay on
BlackTopPat
40
Oct 27, 2004
Lakewood, Washington
ok i seached for an answer to this and i talked to tsunari, who did the same install. ok i got the car on tues and he had just installled the timer. but it wont stay on when the car shuts off. #1 i dont know how to operate it, #2 im not 100% sure on his wiring so i was wondering if you guys can help me out. here are some pics. the pink wire is now grounded to the same screw as the two black wires.
I had the harness on a greddy full auto and I ONLY hooked up the harness and grounded black and it works fine. You don't need the red/green/prple/brown wire hooked up on the Greddy, I can only imagine with the harness the Blitz is similar? The Greddy says the parking brake and speedo sensor are OPTIONAL. Did the Blitz say anything like that? The manual should tell you.
Good luck!
Coming out of the back of the TT, the purple goes to the E-Brake the two black wires get grounded.
The way the TT works, you push the button on the left till you see OFF in the display, push it 3 more times, now here is where you would set for how long the engine will stay running before it shuts off. The 2 buttons on the right. The left one is minutes and the right one is seconds, you set it to your desired time.
I encountered the same problem and it was because the harness I used was for a 1g, not a 2g. If it's a greddy wire harness adapter, you could the wrong 1 of 2 they make. Do you know where you got the harness and which one it is? Find out. Also, in the event you need a 1g wire harness adapter, I have one I could sell you :D
I hope that helps.
