Burnworth
- 42
- 0
- Feb 14, 2003
this car is a 92 plymouth laser awd turbo 5spd. it has a 2.5" cat back exhaust, g reddy bov, and a k&n. our problem is the tailpipe is black, it crackles and pops when you shift gears. when you give it gas to go up a big hill the turbo goes up, but it slows way down. you take the gas off of it and just lightly give it some and it goes.we changed the oxygen sensor, but it made no differance. you unplug it and it runs the same. i think maby its the ground on the exhaust will that make a differance on or off? i wired it back on with a clamp, or also maby i wired it wrong cause you had to use your old plug and there are two white wires maby backwards? i switched them around and still ran the same. any ideas?
