ECUflash black box tuning help
You just need a Tacktrix 2.0 cable if the car is a 98-99, if it's a 96-97, I think you'll need to add a wire and pin to the ECU connector to flash.
When I set the base ignition timing on my car, I used the actuator feature in evoscan to set the timing. It's located in the bottom right of the program. I had to select the correct ecu but after some failed attempts, it did work.
It's obvious when it does work, as you hear a change in the cars idle.
Once the actuator is activated, follow the normal steps of setting your timing with a timing light
I did try using the plug, but it didn't do anything (96 engine wiring harness in a 98 with 98 ecu :idontknow:)
(Edit: this is what I did when running a black top 1g CAS with a 98 flashable ecu)
