BISS screw+DSMLink
eclipsyco
607
27
Nov 19, 2011
Somewhere in, Central America
Car was running fine and I have already done this with my old biss screw.
So I got a new biss screw with o-ring and cap from mitsubishi, took out the old biss and replaced it. When I tried to adjust it with link nothing happens for some reason my ISC motor which is a few months old is maxed out at -0 at the operative temp of the engine why?
Doesn't matter how much i turn the biss the idle will drop or go higher but the isc stays the same or just move a little bit like -4, -6.
Adjusting the biss with link is the easiest thing on the planet but not in my case I'm probably doing something wrong or what?
I follow VFAQ 2G BISS Adjustment, this video and read a few threats on the video Jafro is logging the isc and the Learn Idle Offset, for some reason I can not log this last one just as a raw value is that normal?
Tuning 102 - Idle Tuning - YouTube
i odnt know if it applies with the link, but did you jump the harness? Again, i dont know if its necessary with d-link.This is the only thing i can think of
If by jump the harness you mean ground it then yes I did, with link it can be done just by clicking the 2 boxes under the misc tab.
