bigger turbo??
alanstalan
May 20, 2005
Shady side, Maryland
i have a big 16 g now, when i go to get something bigger so i keep the stock coolent lines?? or do some get blocked off or just get new hoses?? i see that there are about 2 or 3 coolent lines on the turbo?????
thanks
alan
Alan,
It depends on what turbo you buy. Any TD05 frame (EVO III, Sleeper 16G, MHI 18G) will use the same coolant and oil lines. There are others on this list, but those are the basic ones just to give you an idea. The exception would be higher end ball bearing units that only use oil to cool the turbine.
Cheers,
Andy
It all depends on the turbo you choose to upgrade too. There are only two water lines an inlet and an outlet. Some center sections are oil cooled only and some are oil and water/antifreeze. From the ones that I have seen ball bearing models are usually both, its some of the standard bearings that are only oil.
so if i get a bigger turbo only oil cooled do i just block off the old spots in which the lines were goin to my old turbo?
thanks for the feedback!
alan
