Big16g 34mm flapper o2dump and there is CREEP??
update:
so i pulled the turbo this weekend and attempted to port. Well I might have removed 1/16" on one side.... but i did open up the WG hole on the o2 dump....somewhere between the two the creep got much better.
by the time i hit redline it only creeps a couple of psi....guess i can deal with that for now
I want to do the cut the area between the wastgate hole and turbine outlet but I cant figure out how to get my exaust housing off. I took the band clamp off but I can seperate it fromt the center section. Do I just pry on it like a bi*** or what?
Drew
LOL....well i just pulled it all out ;)
mine would not seperate either so i stuffed rags inside the holes....i was in a hurry though....i imagine if you soaked it a couple of times in like WD40 or something it will sep pretty easily. Thats what i had to do the last time to get the exh mani bolts out.
I know this sounds harsh, but just take a rubber hammer or a regular hammer and give it a few smacks. Make sure your holding the turbo strait up with the exhaust housing on the bottom. I had the same problem. Even after I got it off, the next time I had to do the same thing.
smokehouse 83: tell me how it goes after you port it out.
