Big 16G, Used 550CC injectors
WhoTippedMyCoW
Apr 4, 2007
Columbia, Pennsylvania
I just bought a Big 16G and used 550cc injectors. They were said to have come off a japanese EVO and had 11k kilometers on them. Is this ok? They were cleaned or w/e.
I thought evos had 560cc injectors stock. It seems like the japanese cars would have the same injectors. And they should be fine if they only have 11000km on them.
Mitsubishi used 560cc injectors on all of the newer model Evo's. they're probably off of an Evo III. there was a couple of years that they did use 550's.
As long as they have only been run 11k kilo's there shouldn't be any problems with them unless really bad gas was run through them. and if they were cleaned as well you should be good to go.
