Big 16g,rewired walbro 190,680cc injectors,93 octane what do u think?
I have pte 680cc Injectors,Rewired walbro 190,93 octane,big 16g turbo, i was wondering if its enough for 22-24psi? if i wanted to push more then 24psi i would need a bigger pump and injectors right on pump gas? I have a custom erpom ecu chip for my mods now but i do plan on getting dsmlink the chip has:8000rpm rev limit,680cc injector compensation and deadtime, 2g mas compensation, custom fuel and timing maps. Octane reset, fuel cut removed. My wideband reads 10.8-11.1 at 22-24psi.
My EXACT old set up. I went 12.60 at 109 but I had DSMlink. I was at 24 psi and I think like high 8x% IDC. Get Dsmlink as fast as you can. That was the best mod out of all of them.
Bone stock block. Never touch but for a new timing belt.
Sweet! Yea everyone was telling me with my setup im def gonna do 12s but i dont have a logger or dsmlink just a custom ecu chip for the mods my afrs are pretty good like 10.8-11.1 at wot 22-24psi havent blewup anything been running it this way for 1yr i dont know knock or timing though but its been fine and i have arp bolts threw out the motor also my big 16g is ported and clipped so is the o2 housing and 2g mani!
The dude i bought it from tuned it with dsmlink but removed it and then had that info from link put to a chip so it should be fine.
If you're looking to get 20+ psi, make sure you have apr studs for extra security.
Sent from my A70S using Tapatalk
yea i got arp bolts threw out the motor.
Also u think i can go more then 24psi with my setup? How much boost is safe but to get the best potential out the big 16g 24psi or more cause i dont wanna max it and blow it up?
it might hold up for a bit but it will start leaking at anything past 26psi, that was my problem so i bought a new one and it works great now.
Some will hold up, some won't - there's one way to find out. Worst case scenario is it leaks and you have to mod it.
