Best rim size??
Like 11Banger said, it depends on what you plan on doing with the car. Most drag racers want the lightest rim possible to have a lower rotating mass, so a 15" or 16" would work well. If you are aiming for better handling a 17" or 18" will be better because the tire will have a shorter sidewall.
At the drag strip a lower rotating mass is definitely the way to go. I also have a 2005 Dodge Magnum Rt that I occasionally race and I dropped 2 tenths of a second just by switching from my 20" rims back to the 18" rims that my car came with!
Stock for a gs is 16. Gst and gsx are stock with 17. Most drags will have smaller rims while streets will have larger rims with low profile tires. Depends on your goal.
