Best place to tap boost gauge?
90Tsi AWD
77
Jan 5, 2006
Long Beach, California
I did a search and it seems like opinions differ when it comes to where to tap for the boost gauge. I just bought a mechanical AutoMeter gauge and want the most reliable source to hook it up to. Some people say to the throttle body and some to the fuel pressure solenoid, what do u guys think? also if anybody has a good write up of both that would be greatly appreciated. thanks:thumb:
Fuel pressure solenoid, for sure. And don't use the tiny white nylon tube that comes with many boost gauges. Get an adapter for 1/8" rubber hose. It won't kink or crack and will be easier to work with.
if you go on the greddy site and look at they're profec b spec 2 manual it clearly states that for some reason on an eclipse and a supra you need to tap the boost vac. line between the FPS and the throttle body.
