best options
96_4g64t
Apr 9, 2008
san antonio, Texas
i have a 96 spider 2.4 has an awd conversion and turbo but the engine went out so i am planing to do a 2.4 block whit 1g head what do i have to do and will i need to get the engine harnest or will the same one will work
Your harness will work, You may have to switch to a 1g cas( Cam angle sensor) Instead of having a can and crank sensor, I am not 100% sure if you can put a cmp sensor on a 1g head , Either way, You can wire in the cas. You will need cam pully's from a 94 galant gs(2.4 Dohc) And the timing belt, Or you can use adjustable cam gears, You will need freeze plugs to block off the oil passages on top of the block deck, And lower compression pistons.
This link is awesome...
4G64 FAQ
