Bead Form Tool [Merged 8-7] beading beaded tube tubing
STARION
193
May 30, 2002
Nova,
hey, well, I am beading my IC pipes (using JB weld) and am wondering if it matters hugely how thick the beads are. I don't want them to be so big that I have to wrestle to put on the silicone couplings. I'm thinking that more than anything, just having a bead will help, and making it taller will not net a huge gain. However, I also want them to hold boost, just wondering if anybody has any insights
you already answered your own question! Not super thick that you cannot put it on. However silicone is much more flexible so just use your common sense here. As long as the clamp have the bead as a "stopper" from blowing off you'll be fine.
If you are using rubber hose couplings those are much more unforgiving, too big and it is impossible to get it on or off.
with a dremel and a welder you can make one out of a set of lock-jaw pliers or a small vice if you have one
Keep in mind that most bead rollers you buy come with 3" rollers. You can get smaller rollers for them but at the tune of $60 or so a set. Ive got one with 2.5" rolles but it wont work on anything smaller than 2.75" piping. I would just recomend having a bead welded around the perimeter of the pipe.
What type of metal are you working with? With steel exhaust tubing you can do a very acceptable job with an adjustable crescent wrench. Fit the jaws over the lip of the pipe about 1/4" down and bend outward a few degrees. Work your way around until you have an even flare. Then work it back in at about 1/8".
:thumb:
i thought i invented that method, but someone else has done it too :p
Flaring and for me has worked great. I did it with a ball peen hammer and a small anvil point. Just open up the edge a little to give the clamp resistance.
I was wondering if anyone knew of any tool or DIY tool that would allow you to roll good beads on 2-2.5" ID aluminum pipes? I know I can just slap a weld bead on there or use epoxy/RTV to seal the silicone couplers on hardpipes, but if I can find a way to make a real bead I'd be a lot happier. I saw the modified vise-grip idea on RRE's site but was hoping there was something cleaner.
HighPsi92GST said:
Sorry read it wrong, thought it said bending ROFL
i did mine by welding a lip on the end and worked fine for me. sorry about my other post, deleted it to hide my mistake :shhh:
LOL, no problem, I deleted my previous message as well to help you hide your mistake ROFL. I may go ahead and try welding a bead on the pipes, but they are 16 gauge aluminum and I don't know if I can pull that off with my equipment/experience. I think I may try flinguist's method of hairspray and t-bolt clamps, but I might substitute spray adhesive just for long-term peace of mind :)
Before i welded beads on my own pipe, i just used sealer and t clamps and never had any trouble at all. The only reason i put a bead on them is because i got a new welder and wanted to try out welding beads on the pipes ROFL
:thumb:
Shit, my pipes blew off at the tracks @ 20 psi. I had to wait 2 hours for my car to cool down before i got to work. Bead your pipes. Its a quick trip and a few bux for some good safety in return.
