battery not charging after rx7 fuel pump install
250lemans
103
Dec 4, 2002
could a fuel pump draw all the power to itself
for a start, beside boost creep car was fine(96 talon) so i decided to install the fuel pump(3nd gen rx7 93-95 turbo) flows around 220+/-, after installing it car wouldn't start, jumped it it started fine, drove for an hour, dimming lights, car wanted to stall if i used electric things all at the same time, so i got home turned the car off boom died, no power none whatsoever, jumped it again and it started fine, turned it off, dead on power
that's it, thanks for the help in advance
well obviously the rex's pump is alot bigger and byt that i mean more flow and what not but n e who.......to make a long screw short.......did you completly run new wires for the pump r your wires big enought to run the juoice the pump is gonna need is it hooked up right?................sounds like a wire is crossed and is causing a bad draw easy way to find out ...............pull out the key pull the fuse for any interior lights and rado and cig lighter..........take off positve terminal touch it slowly and gently to see if you get a spark listen carefully too if soooo thats right were your draw is i betcha
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
