base tune for my car?
Aproductions
2,123
50
Aug 11, 2009
Allentown, Pennsylvania
Alright guys so I am a noob to tuning....I have a 99 with reflashed ecu and I am using evoscan and ECUflash.
I ordered all this from dsmchips.com and was giving a base tune so I could just drop it in and go.
For the base tune, you answer questions about your setup.
this includes what:
piston compression
fuel pressure
Maf
injectors
So I wanna know how I can get a base tune for my new setup until I can afford to go to the dyno.
now with my build I have 9:1 pistons instead of 8.5:1
Basically if I answered those questions on dsmchips about my new setup, what would be changed from my old setup?
So your question is how to get a base tune?
You go and take some logs (idle, cruise, 3rd gear WOT pull from about 2k to redline). Then you evaluate the data in the logs and make adjustments to airflow, fuel, and timing. You'll want to make sure to have your wideband outputting a signal to the ECU so you can log that value.
We can't really give you a 'base tune' for you car, as we have nothing to base the info off of.
All depends on what break in method you choose for your car (I'm guessing you have a new/freshly rebuilt engine in your car or one is going in). Please do some searching if you're looking for more info on this as there is plenty on here.
As long as you keep the boost low (I'd suggest hooking the wastegate up to your boost source, no MBC in line) you'll be fine. There should be no knocking as long as you're just driving it and not beating on it.
