BAse timming setting?
curt2go
109
Aug 18, 2005
calgary,
I have a 2g auto. I also have a 1g CAS. I was wondering what I could set the base timming to with 15psi on a T25. Because its an auto I would like to raise the base timming to help with boittom end which is lacking.. Let me know...
Thanx. TTY
I would stick with 5* base. If you raise it, it will raise your lower end power, but because you have so much advance, it would either hurt your high end power, or hurt you internals.
Stick with stock settings for timing untill you have extreme mods.
Then I guess I might as well not put th 1g cas on yet then? Cuase it is set at 5 right now.. TTY
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
