Base timing question
95_Talon_nt
Jul 16, 2004
Lewisburg, Pennsylvania
Is there any other way to check the base timing without the lower timing belt cover on ? My cover was all messed up so I took it off. I have a timing gun and know how to use it I just wanted to know if there was any other way to check it. Someone said they used a pocket logger. But if your camshaft position sensor was moved then your loggers base timing setting and output for regular driving output would then be incorrect right?
Thanks- J
btw the car is a 90 eclipse fwd gs -t
The output displayed on a logger is based on the ECUs assumption of a correct *5 base timing.
Only way to do it right is get a good cover on and put the timing gun on it.
Thanks I didnt think there was any other way but it wasent shure. I'll have to order a new one. Thank you :dsm:
