Balnce shaft tensioner
killab443
602
3
Nov 24, 2003
Howell, New Jersey
I over torqued the balance shaft tensioner bolt and it boke inside the front cover. I had gasket maker on it when I put it in, am i going to leak oil? That bolt is in there really good with a pretty clean break. (i eliminated the balance shafts)
Did you use any type of tread sealant, if not you might get a little bit of a leak, try to use an easy-out then get a new bolt and out in place of it.
