timing belt and balnce shaft removal tips
bmxcoolcat1
34
Nov 19, 2008
bowling green, Kentucky
im about do for a new timing belt and i was just wonderin whats a good performance timing belt and should i remove the balance shaft while i got the side of motor apart and how would removing the balance shaft affect the car would it run rough or will it still run smooth
All of this could have been found with a quick search.
Use an OEM timing belt.
Balance shafts are your choice. If taken out the car might shake a little but that is it.
I have always run and heard to run the OEM timing belt or the HKS belt. My car is the 2.4 DOHC and I have only been able to find the OEM timing belt. As for the balance shaft removal, I would do it just for the assurance that you will not loose the balance belt and then it messes up everything in the engine by messing up the timing belt. The only really noticeable differences that you will have is at idle it will vibrate a little more and the oil pressure in the engine will rise since you need to block off the oil gallery that goes to the bearings that receive oil from the engine block. The bearings that receive oil from the actual oil pump receive it through the actual balance shaft but the other balance shaft receives oil through the oil gallery in the block.
1. Learn what a "wiki" is.
2. Post in the correct forum
3. Post in English, and save the "I'm from Kentucky" BS I've heard from other members in your state.
Enjoy.
