Balanced a Clutch for my 1G Documented
MadSciHighPSI
5
Apr 18, 2018
Milford, Connecticut
Long post on clutch development and the possible importance of clutch balancing for applications. Yes, this is likely overkill, but transmission parts are unobtainiun and I'm sick of changing clutches.
Forward: Speaking with a few transmission builders and going through a few clutches keeping the clutch as my fuse to prevent gears from shearing in over torque situation.
Combination = full weight 1g DSM 6 bolt AWD with 340 tq and 396 HP.
Previously clutch combos
2600 ACT + act street disc stock flywheel = burnt street disc
Southbend TMZ prepped 2900+ act street disc and act flywheel TMZ prepped = burnt disc
Southbend 2900 TMZ prepped+ kevlar disc + act flywheel TMZ prepped = welded to flywheel (likely due to clutch drag after 2nd adjustment = user error)
New combo = TMZ 2900 Southbend prepped + kevlar/carbon towards flywheel + ACT TMZ prepped flywheel.
Attached are images of clutch balancing because I was urged to balance the clutch + flywheel + pressure plate
Factory crank was out 3.6 grams, got that to 0.6 grams out of balance
Act flywheel applied and stayed at 0.6 grams, so that was balanced properly
Pressure plate applied and was out 2.6 grams and after slight grinding was out 0.6 grams
Will this make a difference? I have no idea, but wanted to share with the community.
Pictures attached of balancing final spin and before final spin of balancing.
