Balance shaft plug
Awsniper
41
Aug 28, 2005
Honolulu, Hawaii
Where is the Balance Shaft plug located, i just wana make sure that my balance shaft is properly timed and lined up. Does anyone have any pictures of the location, becasue i cant find it.
Thanks. I think that could be the problem with my timing. If its not that, then i am gona take it to the shop. No check engine Light, Runs like crap. Its weird, it doesnt smoke until i give it Gas. At idle it Putts like a V8, and Smells like straight gas. But No Smoke. Whole car shakes at idle. I am out of ideas if this is not the problem.
Mine did that as well, check your compression. I ended up melting a little hole in my #1 piston. Also, check the shaft play on your turbo, up/down, in and out. Get back to us when you do those :D
Chris:laser:
