bad vibration!
reutterj
Sep 16, 2004
Gretna, Virginia
I was drivin to work today and it was fine then i went to change lanes to the right on the high way and i got a bad vibration, there is none goin to the left or straight. i pulled off the road to see if the lug nuts came lose but that wasnt it, and there is no clicking inthe CV joint either. Any and all help would be GREAT!!!
o by the way its a 97 GSX eclipse
all the CV joints are good but there is no real way to check the wheal bearing unless i can take the CV joints correct?
Jack the front of the car up and take the wheel and try to move it up and down. It shouldn't move at all. If it does, your wheel bearing may be bad. Also, check your motor mounts to make sure all the bolts are tight.
ok i found out what it was it was just the nut that holes the break rotor in place came a little lose, i guess the cotter pin broke
Good thing you caught that. Torque that sucker down good (150 ft.lbs.) and get a new cotter pin. Check the other side too.
