Bad Vibration
mnexcited
39
May 2, 2004
Lino Lakes, Minnesota
I searched to see if anyone had this problem, seems like the answer is yes except I get a vibration with clutch in sitting in the driveway. Seems like between 3000 and 4500 rpm I get a very bad vibration. Balance shafts are removed and a stock rebuild was performed about 3000 miles ago. Here's what worries me, this started about 300 miles after I switch it to full synthetic Royal Purple. I'm having trouble putting my finger on what in the motor could cause the vibration. I'm hoping it's something clutch related but if it's not any idea's on what it might be otherwise are welcome? I've also check crank pulley, cams, and anything spinning that I can see and it all seems fine.
Nick
I did the BS removal and yes the shafts are completely gone and done the correct way. NO there are stock mounts, also the assemble was installed in the order it was in with new bearings. I'm leaning more towards time side or clutch now, but that is just my gut. I think I'm pulling the motor tomarrow. :rolleyes:
