bad things happening
Status
Not open for further replies.
9D3GSX
Oct 15, 2003
orlando, Florida
I have a 1g awd and i have the worst luck with it. I have spent a lot of money fixing everything up in the car and i just cant see the light. My current problem is my transmission moves everytime i hit the clutch causing the t'case to contact the flywheel. This is due to the ear on the block where the transmission bolts to is completely broken off. I basically have 2 strong bolts holding the tranny in and that is the upper ones. If anyone can think of a fix please don't hesitate to let me know. I have built the hell out of this car and i would appreciate a little something in return.
You have to pull the block out and replace it, or get the ear welded back on.
There has to be a reason why it broke off, I would look into that.
It sounds like you have no option but to weld the ear back on. Is it in a place that a welder can get too w/ out pulling the block if you remove some things around it?
you have to get it welded with eather a 110 or 220 arch welder with nickle rods wich are about 15 bucks a piece.
Thanks for reviving this to add what 2 others previously stated. :|
Status
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
