bad oil leak from timing cover area
Go to Napa or carquest and ask for UV dye. They say its not for oil but its fine to use. Just put it in your oil, grab a black light and crank the car. Then just look around for neon green shit. You will have then found your leak. Works for me every time :)
i might have to try that i de-greased it 2 times this time i have left the timing cover off to see but last time i ran it before i put it together holding steady 3000 rpms it never leaked so i don't know that it will work unless i boost the car
I ended up having yo put the dye in and taking it for a short drive. Then immediately jack it up and check it with a black light. My best guess is it's coming out of your oil pan gasket and getting on your timing belt splattering it everywhere. Or, its coming from a seal on your front case somewhere.
i originally thought it was but my new timing belt has not a drop on but the case behind it is covered i figure it had to be coming somewhere between the tensioner and the crank the head and up is oil free, my seals all looked good and i have another new set in case but i want to pinpoint the leak idk if maybe the idler arm could be leaking or what it could be
I was having this same problem. Did you pay attention to your crankshaft seal when you put the case on? I found mine was because the seal was not aligned correctly around the crankshaft.
