Bad News For New Engine!!!
PaRaNORML
86
Apr 23, 2009
jacksonville, Florida
i am so angry right now i just put my new motor in and new tranny yesterday car was riding good during break in,an oil line to the oil filter exploded ,so i inched her back home , this morning i fixed the oil line and went to start the car , the entire engine and tranny just shake pretty hard, and car has slight vibration, attempt to rev resulted in more vibrating and shaking WTF is going on please tell me the motor isnt blown
Did you over heat the engine while nursing it home? I can't see how the engine oil prob' could affect your tranny, but it could just be symptomatic of the engine vibration and that could be from any one of a dozen things that might have gone bad while running with little to no oil for lube or cooling.
How fast were you going when the oil line let go? and did you lose all the oil afterwards? The bearings might be ruined or you might have a spun bearing. Depending how quickly you shut down and how long you drove it after the line broke is going to determine what kind of damage you have.
have you tried starting it again? does the problem still exist or any load knocking or rattles? with out a tear down to inspect vital components it's going to be a crap shoot as to the exact problem.:cry:
So wait... an OIL line exploded & you still drove it home knowing that? WTF
when it blew i drove straight home about 1 mile maybe less, i attempted to start it today after replacing the line, everything is vibrating alot,so drain the oil , replace and then go from there? or do you definately think its a problem in the motor?
Well, if you drove it with the oil line broken and no oil pressure, then the engine is most likely fried. Did it run out of oil? Did you lose oil pressure? If you drove it for any amount of time with either of those being true then yes, the motor is blown.
Yes..
Did you even check to make sure you had enough oil before trying to start it :pray:
problem solved, i pulled the spark p,ug wires and re connected them started the car and all vibrations went away
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
