Bad Gas Mileage [Merged 9-6]
99GST
245
Dec 26, 2001
Nashville, Tennessee
I am still getting some pretty bad gas mileage.
I am only getting about 19.7 mpg with mostly city driving shifting at 4k.
I have already replaced my front O2 sensor and am looking to replace the fuel filter.
I have a 99gst with about 55k miles on it. Should my fuel filter already be bad?
What else should I check or change? I have NKG plugs and Accel wires are on the way.
Thanks,
Nathan
No not really. When my o2 sensor went out, mileage decreased and it ran rich. Of course every situation is different.
Try a tune up if nothing else.
Boost leak test,
Spark plugs and plug wires,
Maybe cleaning throttle body and whole intake would helped a little(helped me)
More than likely O2 Sensor if you don't have a CEL.
I'm in the same situation trying all this stuff. Filled my tank and was down to 1/4 of a tank in 80miles. :notgood:
I have a 98 GSX automatic. I'm getting under 200 miles per tank which to me is horrible gas mileage considering its a 4-cylinder. Not sure if something is wrong with my car or what? Anyways I was wondering what are some upgrades or anything I can buy for my car to increase gas mileage
I'm fwd but,
How are you driving, when I drive hard or I'm boosting more then other times I can get about 175-200 miles to full tank. When I drove 487 miles 2 weeks ago at 63 mph, I got 38.3 mpg. OMG I didn't think would get that good. On the way back I wasn't so conservative and got little less then 12 mpg, 13 psi 14b. Stock fuel at that time. Saved only 30 min also not too worth it :idontknow:. Food for thought.
A lot of conservative city driving your going to be around 20mpg give or take a few, probably take, :ohdamn: Would be my guess. So reset your trip when you fill up and divide miles by how many gallons you put in and see where your at.
But I hope this gives you an idea. Sounds kinda normal to me
Its a 2g so its an obd2 car i would suggest to you a elm 327 scanner you can get one for under 10$ on ebay its a bluetooth adapter that plugs in and get on your phone assuming you have a smartphone torque pro its i think 4.99 and you can log everything you need with it and check trouble codes i have 13$ into my setup for logging granted i dont have my dsm anymore but i used it to tune my 2g with an safc and worked great one of the best investments i made for that car and i still use it for engine lights in curtent car or friends cars so on
That sounds perfect thanks for the help guys I will do this for sure!
