Bad FPR?
awdtalon4451
521
Aug 23, 2007
Ocean springs, Mississippi
I currently have the stock fpr on the car. I bought some Denso 660's and installed them. Car ran like poo under boost (10psi). Thought it might be cause I don't have an ajustable regulator. So I put the 450's back in, car still runs like poo under boost. Has a small boost leak from one of lower injectors seals.
Basically the car runs good at idle and low rpm cruising. but anytime I give more than %30-40 throttle or the engine sees a moderate load it runs crazy rich especially when it starts seeing boost. I was seeing 8.9-9.6 A/F's. I tried leaning it out with my SAFC but didn't do anything. I have a greddy fuel pressure gauge tapped on top of the filter and it stay between 2.5-3 bar.
I read that bad FRP's will give a false rich A/F's. Can you test a FRP? Or is it just buy a new one?
Just wanted to update this thread. I've been tinkering with it off and on the past week or so. I fixed my boost leaks and replaced all upper and lower injector seals. It helped a little but didn't fix the problem. I wound up replacing CTS and lower temp sensor, reset the ECU afterwards and it has resolved my rich issue. Hope this helps
Yea i had one from awhile back. Was leaking from TB gasket, TB shaft, lower injector seal and BOV. All small but were still evident. I am how ever still leaking into the exhaust mani. I didn't test when all the valves were completely sealed though.
