bad driver side axle?
edikshion
Dec 17, 2009
las vegas, Nevada
Every time I take a right turn there is a grinding noise coming from sometimes the front and sometimes the back . If I take a right turn and accelerate slowly then no noise , but if I give it gas or load it makes a grinding noise ( almost sounds like a tire rubbing on something , but its not) When there is people in the car the sound gets louder and worse. I am thinking it is the driver axle because it doesnt make the sound when im just turning right but when I give it gas when im taking a right turn . I checked under the car and both control arm joints are torn but that wouldnt make a grinding noise when im turning right?
The noise.... deep Sound ,like 2 rubber/plastic rubbing together , no metal on metal.... yet.
Mine did that right before my axle died. If you pull into a driveway slowly but still accelerating then its probably the axel. The other symptom i had was the steering would jerk once in a great while. If it does get it fixed immediately, it sucks to have to flat bed your car home after a shop tells you its the control arm.
well my car originally came with rs rims (14 inch rims with high profile tires ) then i bought the gs rims ( 16" with med profile tires ) but i look around and theres no symptoms of the wheel hitting the walls or anything , anyways these are pictures of my cv joint driver side , other side is exactly the same
Pictures are upside down btw
<a href="http://s181.photobucket.com/albums/x181/aricandsuzanne/?action=view&current=0224000945.jpg" target="_blank"><img src="http://i181.photobucket.com/albums/x181/aricandsuzanne/0224000945.jpg" border="0" alt="Photobucket"></a>
<a href="http://s181.photobucket.com/albums/x181/aricandsuzanne/?action=view&current=0224000946.jpg" target="_blank"><img src="http://i181.photobucket.com/albums/x181/aricandsuzanne/0224000946.jpg" border="0" alt="Photobucket"></a>
Replace those ball joints, before they kill you.
Grinding can come from ball joints, (usually while the wheel is being turned, or going over bumps) axles, (usually manifests as a popping sound, though) brakes, and wheel bearings.
I will replace my driver side soon. Mine doesnt sound like grinding though, it is more like a "clank" sound every time I take a right turn. Like other people said check the ball joints. Just take it to Mitsubishi and they will look into it.
  • For sale 1g 1991 Eclipse GSX
    1991 Eclipse GSX $7,800 100,500 miles Clean Pa Title In Hand NO Trades Manual Transmission...
  • For sale 2.3 Stroker Galant VR4 Roller
    2.3 stroker block, forged rods and pistons. Needs to be gone thru (ballhone, rings and bearings...
    • brane_97talon
  • For sale New OEM style 2g Headlights
    New 2g OEM style headlights. Bought for my Spyder turbo conversion. Car long gone.125 shipped...
    • brane_97talon
  • For sale Hafe Stainless Exhause Manifold with External wastegate and welded 7cm housing
    As pictured, HAFE stainless exhaust manifold with welded 7cm housing. Bolt on TD05H setup. These...
    • brane_97talon
  • For sale JDM Valve Cover
    As pictured, JDM Valve Cover. Good condition. Bought about 10 years ago, possibly from the same...
    • brane_97talon
