Bad belt squeal
justinh2k
Dec 24, 2008
Sterling, Colorado
well im pretty sure its my power steering pump and belt doing it..it looks like the alignment is all outa wack..problem is, is that i dont know how to realign it..i know how to tighten it..the pump is leaning away from the engine..how do i realign it?
You can't adjust the pulley other than tightness. Take the belt of completely and check for play. You may need to replace it. Also make sure that the two pullies on your waterpump are stacked in the correct fashion, smaller one on the inside, bigger one on the outside with the offset making them as close as possible.
