2G Bad axle/CV joint?
boostd-spyder96
44
Sep 20, 2008
jackson, Tennessee
ok i have a 2g and recently i will hear a clicking noise every so often when i turn(doesnt happen alot tho)..so i thought it was my cv joint..but when i looked under the car none of the boots were torn.so i was wondering how else you can tell if my axel or cv joint is bad..i've also started noticing oil spots under the car when it sits for awhile(im thinking trans fluid).it looks like it might be leaking from where the axel goes in to the trans...could my seal just be bad???any help???
change to transmission fluid and see if it goes away. push the boot in to see if there is any grease inside of it.
ya i planned on changing it but i dont want to change it yet if its just gonna leak back out..i bought royal purple because i was told it was good stuff:)..ithought it must be if im spending 80 bucks on it..
