General Bad airflow?
timloomis
925
15
Jan 28, 2003
duncan falls, Ohio
I can not get my WOT tuned right. I'm running 10 psi more base fuel pressure with the N/T FPR on my RC 550's. That turns them into 640's, which I have the MAFT set for.
My fuel trims were around 100% until today when they all went lean for some reason, around 127%. I just installed a new Walbro 190 and it's rewired, and I have a new fuel filter.
My logger shows my IDC is around 90% at ~5500 rpm on. Narrowband O2 voltage is at 0.89 volts, and the logger maxes out the 1606 HZ airflow at ~4900 RPM. I'm still on the 14b at 17 psi. It's still knocking 10 or so counts even with adding 5 clicks with the MAFT WOT knob.
Thought it was rich knock so I backed it off 4 clicks, and knock went nuts. Also zero boost leaks. I've changed 2 GM MAS sensors just to be sure, and I'm still having this problem. This has to be a bad MAFT right?
I don't want to spend 150 on an SAFC unless I have to. There's no way in hell I'm maxing out 640's at 17psi with an unported 14b. Timing is right on at 5* BTDC too.
Are you saying that you have a nonturbo fuel pressor regulator? Are the n/t fpr' a rising rate fpr? I did not know that they were made for boost. It would be easy to check if it was.
Yea they rise on a 1:1 just like a turbo fpr.
  • For sale 1g 1991 eagle talon part out
    Hi guys the time has come to part out my long time project car. Lack of time and a rotting frame...
    • 91tsi_awd
  • For sale 4G63 1G/2G rear manual ring and pinion
    1G/2G rear manual ring and pinion$80usdMsg me if interested
    • Dsm_canadian_mike
  • For sale 4G63 Spare parts
    Some parts leftI have already thrown some parts away this is what I have left I’m giving it a...
    • Dsm_canadian_mike
  • For sale 4G63 FIC 850cc injectors
    Selling a set of 4 FIC 850cc injectors in good working condition,only 93 pump gas been running...
  • For sale 1g PTT Twin Disc for sale
    Twin Disc PTT clutch for sale
    • erikoberdorfer
