2G Bad AFR reading
Michael Wucher
Supporting VIP
53
11
Apr 19, 2020
Norfolk, Virginia
Hello all, looking for some advice. Recently my talon has been struggling to take off from a stop (car drops to around 500rpm idle and tries to die out, and AFR spikes 19-20) but once it gets going its fine. Today I did a little pull and noticed AFR was pegged at 22, while full throttle, also it definitely was not pulling as hard as usual. At idle, the AFR is around 15.5 spikes to 17. I'm thinking it's a possible boost leak, I plan on testing this weekend. Any input would help, thanks!
Please don't do a WOT pull until you fix the issue. You may possibly finish the engine.
Yes first things first, do a boost leak test. Also please check you alternator and battery voltage for voltage drop. It would cause a similar issue.
I did kind of wonder if the alternator is slowly going, i notice at night time the dash lights will dim slowly then go back to normal brightness
Does the car run normal when the engine is cold and those symptoms appear more often when the engine is hot? If so, you should definitely check the voltage when those symptoms appear. Maybe a bad/weak alternator (including voltage regulator) or/and battery is the cause.
the symptoms appear both hot and cold. I'll definitely look into the alternator!
