backfires underboost?
MrdB
52
Jun 28, 2004
Chillicothe, Ohio
heres is my motor mods.... when ever it builds full boost it backfires like its hitting rev limiter? every gear.. never fails? please some1 help me!
JDM 6-bolt 4G63 engine
.020 over Ross forged 8.5:1 Pistons
Eagle H-Beam forged rods
NGK BPR7ES spark plugs
MSD Super Conductor 8mm Plug Wires
Forced Performance 4" intake pipe
3" GM MAF with MAF Translator
Forced Performance "Red" Model turbo (60-1 compressor wheel / TD06H turbine in a 7cm housing)
2g Mitsubishi Eclipse turbo exhaust manifold with wastegate off #1 runner
Hallman ES manual boost controller
Ported 2g o2 housing
29x10x3 spearco front mount intercooler w/custom 2.5" stainless steel piping
USDM 1g Eagle Talon Intake Manifold
Custom 3" exhaust w/3" A'PEXi N1 turbo muffler
Tial 38mm external wastegate
GReddy Type S blow off valve
Precision Turbo 680cc injectors
Forced Performance FP2 (272) cams
Walbro 255lph fuel pump
i have a maft setup with a safc... the car runes great.. untill it hits full boost... u think i may have a boost leak?
I'm not sure. It never hurts to check. A boost leak may cause it to run rich enough to make it backfire. But it'd have to be a huge leak. Does it boost fine? Does it feel fast or like something is holding it back?
its a fp "red" so the spool is slow as hell.. once it hits about 18psi its like i hit rev limiter... its really odd.. i think the timing may be off or a leak... i read 10.5:1 on my wideband
maybe check out / replace your plugs.
my car was doing something like that whenever i went past 10lbs and i had my mbc set to 14lbs so whenever i hit full boost it would back fire, or sputter or whatever you want to call it. replaced the plugs and runs like a beaut.
my .02
i change the plug and poof! RUNS LIKE A BEAST!!!!! oh my fooking god.. i recommend a FP "RED" to everyone!
THANKS GUYS FOR THE HELP!!
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
