B O V vacuum hose?
JRock20G
66
Mar 18, 2011
Montreal, QC, Canada
Need Help just got a turbo Put on my 420a everything is great but by blow of valve isnt connected properly, well im just missing a vacuumhose supposedly going to somewhere after the intake manifold , does anyone have a pic or advice on where i should splice into a hose? thanks.
The way most people do it on turbo 4g63ss is to run a dedicated line from either the intake manifold plenum or use a throttle body vac line if you have them. Make sure if you use a throttle body vacuum source you use a correct one because I believe they reference from different sides of the throttle plate in most cars.
I use the source from my turbo, stock, or j pipe with a nipple.
You can't run the bov hose to the turbo or j pipe. There is no vacuum present there, only pressure. It has to run from the intake manifold where there is vacuum present.
I think you are confused, what you discribed would be for a MBC, NOT a BOV
Bryan is correct here, with this statement.
OP any nipple you have on the IM, not in use, that is behind ( engine side) of the TB will work
  • Wanted 6 bolt NT water pipe
    • chrisman287
