vacuum leak
pdub42
35
Sep 19, 2009
Newark, Ohio
Hey, I've been having and issue with the 95 eclipse recently, when the car is cold the engine will rev up every time i hit the clutch, or if im in neutral and just touch the gas at all it will rev up to around 2.5k and hang there for a few seconds before dropping back down. I changed out the intake gaskets because they were leaking, reset the computer and it ran perfect. Next day start it up and it did the reving thing again, I cleaned the map sensor and IAC and now ive got a really bad leak from somewhere with the same symptoms but worse now, (reving higher and hanging a little longer). I can now hear it sucking air around the throttle body area, I took the TB off and put a new gasket with blue rtv and it is sealed still leaking.
I have two questions how should I go about looking for the leak? I know the general area because I can hear it but cannot tell exactly where it is coming from, and also is it still alright to drive the car? I have an hour each way to school and back every day and cannot work on the car until this weekend but I do not want to cause other problems by continuing to drive it.
found the problem, my egr was loose on the intake side.
