2G B&M Fuel Pressure Regulator
talon97
42
3
Mar 15, 2004
Pittsburgh, Pennsylvania
Guys
I put in a AFR from B&M. I am seeing gage readings NO lower than 52 psi. I have a Walbro 255 and rewire, 550s. No other fuel mods.
I can raise but not lower. Are my numbers normal/typical?
Since I did not know my numbers before, I hear ~43ish PSI in normal (?)
Another question, why did I buy this thing? I know I should know. But I do not.
(Good greif Charlie Brown):(
-Thanks for any advice.
Scott
2g, FTP t28/28, 3" turbo back, Supra SMIC, 21psi, etc
This is your problem.... buying things that you do not need and/or buying things that suck (in which case is the latter) :D
Sell the B/M pressure regulator to someone with a Honda that will benefit from upping pressure. If you are going to stay with that settup u probably do NOT need to raise the FP in any case. You have some good fuel mods on there so match them with a proper FPR. Consider a aeromotive, SX, Buschur special or something that can actually adjust the pressure.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
