axle support
XxSiRhCy6PxX
179
Sep 26, 2004
san diego, California
Alright so here is the deal. In the process of replacing my driverside axle seal, i found one of the bolt broke into the bolt and when i went for the other one it also snapped! How will it drive without it in for a while and does anyone have any ideas on how to fix it. :cry:
LOL dont wory your not the only one it happened to me i atually snaped the head of the bolt off. i ended up drilling it out and replacing the bolt. if you can drill it use an easy out. if theres enough to grab you can heat it and use a pair of vice grips
Here is another option. If there is a boss that sticks out on the side of the block you can take a cuttoff tool and cut a notch in the bolt for a screwdriver. Then take a torch and heat it up and turn the bolt out. it has worked for me in the past with broken motor mount bolts. Travis
