beating4g63s
- 525
- 3
- Oct 31, 2004
port arthur,
Texas
heres a little info on that motor it is used for swaps in neons, just about every single eclipse/talon/laser owner hasn't really stumbled across that and when they read that it's rwd they close the page or stop reading there, anyways the tranny that matches up to it is found http://www.hughesperformance.com/street.html here it's the last one on the page, also I believe a s-10 will fit that block, not 100%. I found exactly what your looking at a couple of years ago when I blew my motor and was looking for a replacement, anyways specs on that block you can probably look on neon forums to find out. also making it fit sideways can be done. I've actually searched and found someone who put a 4g63 motor sideways in a 80S model s-10 the box looking one. probably like a 89 or so. and that truck was rwd using the stock s-10 rear end. also a few months ago I was watching car and driver or some show like that, and they did a special on a mini cooper in Europe not the new one but the hella old one, and that some crazy British guy had a 4g63 sideways not sure if it was rwd,fwd, or awd. so having motor sideways can be done. and as for the twin turbo system, theres one guy on the 3g forums that put a twin turbo system on a 3g I believe it was the gs model not the gt. and it worked he had a full build up written to. not sure if he put any numbers on the system, anyways this post isn't like 4g63 swaps, this block is made for neons with 420a motors, so if the 420a from a neon will fit into a eclipse this block will fit. if you actually read the link he posted it says made for neon. 2.0/2.4. plus theres probably never a post about this so he couldn't search for it. so what rule did he break to get his thread locked. anyways I hope I helped in anyway good luck with the block and all.
, the LSD is working just fine in the back but i dont know why it only spins the back tires. Even on dry pavement i can do a great burnout with the rear wheels but nothing in the front. If anyone has any ideas on what is going on i would love some opinoins...thanks
someday. I havent seen any Eclipse drift cars so far, and I kinda wanna stick out, out of all the 240's, Ae86, and FC's.
Wait until you can afford your 240 or whatever RWD car you want. Older supras and rx-7 maybe be ugly, but they can be afford RWD cars with power.
